DMC4029SK4完美替代UD4803/AOD609/
消耗积分:0 | 格式:pdf | 大小:730KB | 2017-08-02
徐亮
分享资料个
DMC4029SK4:完全替代UD4803,DIODES强势推荐!
  Features and Benefits  Low Input Capacitance  Low On-Resistance  Fast Switching Speed  Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)  Halogen and Antimony Free. “Green” Device (Note 3)
  Mechanical Data  Case: TO252-4  Case Material: Molded Plastic, “Green” Molding Compound. UL Flammability Classification Rating 94V-0  Moisture Sensitivity: Level 1 per J-STD-020  Terminal Connections Indicator: See Diagram  Terminals: Finish – Matte Tin Annealed over Copper Leadframe. Solderable per MIL-STD-202, Method 208  Weight: 0.34 grams (Approximate)
评论(0)
发评论
下载排行榜
