ISM波段远程无钥匙进入系统增加了不同应用的价值
消耗积分:0 | 格式:rar | 大小:0.03 MB | 2017-08-13
分享资料个
  无钥匙进入使用一个短距离,相对安全的无线连接有很多机会超过打开车门。连接到电磁阀,遥控钥匙(RKE)系统可以打开存储单元,宠物门或安全的入口大门。更广泛的应用范围包括执行打开或关闭东西的一般过程,如灯、警报器和电器。
  基本的RKE系统工作在433 MHz ISM频段,采用3 V锂电池如CR2032,持续了几年。消耗电流通常小于8毫安。组件包括四个便宜的集成电路:发射机、接收机和两个相同的微控制器,用于编码和解码24位密钥代码。基本的无线系统,如图1所示,可以少于20个组件实现。
  Amplitude-shift keying (ASK) modulation is used in remote keyless entry systems to maximize battery life.
  (Courtesy: Maxim Integrated Products)
  A pushbutton switch – typically on a key fob – initializes the system by waking up the CPU housed inside the key fob, which sends a data stream to a radio frequency (RF) transmitter. Data is typically 64 to 128 bits long and consists of a preamble, a command code and a rolling code. To extend battery life, amplitude-shift keying (ASK) is used as the modulation scheme. The RF receiver captures the RF signal, demodulates it and sends the data stream to the CPU, which decodes it and the command module. This could be something as simple as a solenoid.
评论(0)
发评论
下载排行榜
