低功率四双极运算放大器MC33174-MC35174
消耗积分:0 | 格式:rar | 大小:0.08 MB | 2017-09-05
分享资料个
  DESCRIPTION The MC3x174 series are quad bipolar operational amplifier offering both low consumption (200µA) and good speed (2.1MHz, 2V/µs)。 Moreover the Input Common Mode Range extends down to the lower supply rail, allowing single supply operation from +4V to +44V.
  GOOD CONSUMPTION/SPEED RATIO : ONLY 200µA FOR 2.1MHz, 2Vµs ■ SINGLE (OR DUAL) SUPPLY OPERATION FROM +4V TO +44V (±2V TO ±22V) ■ WIDE INPUT COMMON MODE MODE VOLTAGE RANGE INCLUDING VCC- ■ LOW LEVEL OUTPUT VOLTAGE CLOSE TO VCC- : 100mV TYPICAL ■ PIN TO PIN COMPATIBLE WITH STANDARD QUAD OP-AMPs.
评论(0)
发评论
下载排行榜
