The tcp port used by the publisher:
#publish_port: 4505
# The user under which the salt master will run.
#user: root
#可单独设置,默认遵从于操作系统设置
#max_open_files: 100000
# The number of worker threads to start. These threads are used to manage
# return calls made from minions to the master. If the master seems to be
# running slowly, increase the number of threads. This setting can not be
# set lower than 3.
worker_threads: 5
# The port used by the communication interface. The ret (return) port is the
# interface used for the file server, authentication, job returns, etc.
#ret_port: 4506
#pidfile: /var/run/salt-master.pid
# Directory used to store public key data:
#pki_dir: /etc/salt/pki/master
# Directory to store job and cache data:
#cachedir: /var/cache/salt/master
# Set the default timeout for the salt command and api. The default is 5
# seconds.
#timeout: 5
# Set the directory used to hold unix sockets:
#sock_dir: /var/run/salt/master
# Include a config file from some other path:
# include: /etc/salt/extra_config
# Enable auto_accept, this setting will automatically accept all incoming
# public keys from the minions. Note that this is insecure.
#auto_accept: False
