SGM8542运算放大器的实用参考书
消耗积分:0 | 格式:rar | 大小:0.61 MB | 2017-09-18
分享资料个
  The SGM8541 (single) ,SGM8542 (dual) and SGM8544
  (quad) are rail-to-rail input and output voltage
  feedback amplifiers offering low cost. They have a
  wide input common-mode voltage range and output
  voltage swing, and take the minimum operating
  supply voltage down to 2.1V and the maximum
  recommended supply voltage is 5.5 V. All are specified
  over the extended –40°C to +125°C temperature range.
  The SGM8541/8542/8544 provide 1.1MHz bandwidth at
  a low current consumption of 42µA per amplifier. Very
  low input bias currents of 0.5pA, enable SGM8541/8542
  /8544 to be used for integrators, photodiode amplifiers,
  and piezoelectric sensors. Rail-to-rail inputs and
  outputs are useful to designers buffering ASIC in
  single-supply systems.
  Applications for this amplifiers include safety monitoring, portable equipment, battery and power supply
  control, and signal conditioning and interfacing for
  transducers in very low power systems.
  The SGM8541 is available in the tiny SOT23-5 and SO-8
  packages. The SGM8542 comes in the miniature SO-8
  and MSOP-8 packages. The SGM8544 is offered in
  TSSOP-16 and SO-16 packages.
SGM8542运算放大器的实用参考书
评论(1)
发评论
冷风如刀 2017-10-01
0 回复 举报
感谢楼主大哥分享,感谢感谢感谢感谢 收起回复
下载排行榜
全部1条评论
