DRV8835DSSR直流马达控制器芯片
消耗积分:0 | 格式:pdf | 大小:164KB | 2017-10-11
PCB00031033
分享资料个
直流马达控制器芯片
  The DRV8835 provides an integrated motor driver solution for cameras, consumer products, toys, and other lowvoltage or battery-powered motion control applications. The device has two H-bridge drivers, and can drive two DC motors or one stepper motor, as well as other devices like solenoids. The output driver block for each consists of N-channel power MOSFET’s configured as an H-bridge to drive the motor winding. An internal charge pump generates needed gate drive voltages. The DRV8835 can supply up to 1.5-A of output current per H-bridge. It operates on a motor power supply voltage from 2 V to 11 V, and a device power supply voltage of 2 V to 7 V. PHASE/ENABLE and IN/IN interfaces can be selected which are compatible with industry-standard devices. Internal shutdown functions are provided for over current protection, short circuit protection, under voltage lockout and overtemperature. The DRV8835 is packaged in a tiny 12-pin WSON package with PowerPAD™ (Eco-friendly: RoHS & no Sb/Br)。
评论(0)
发评论
下载排行榜
