AD811芯片资料
消耗积分:0 | 格式:rar | 大小:0.28 MB | 2017-10-17
分享资料个
  The AD811 is also excellent for pulsed applications where transient response is critical. It can achieve a maximum slew rate of
  greater than 2500 V/µs with a settling time of less than 25 ns to
  0.1% on a 2 volt step and 65 ns to 0.01% on a 10 volt step.
  The AD811 is ideal as an ADC or DAC buffer in data acquisition systems due to its low distortion up to 10 MHz and its
  wide unity gain bandwidth. Because the AD811 is a current
  feedback amplifier, this bandwidth can be maintained over a
  wide range of gains. The AD811 also offers low voltage and
  current noise of 1.9 nV/√Hz and 20 pA/√Hz, respectively, and
  excellent dc accuracy for wide dynamic range applications
  The AD811 is a wideband current-feedback operational amplifier, optimized for broadcast quality video systems. The –3 dB
  bandwidth of 120 MHz at a gain of +2 and differential gain and
  phase of 0.01% and 0.01° (RL = 150 Ω) make the AD811 an
  excellent choice for all video systems. The AD811 is designed to
  meet a stringent 0.1 dB gain flatness specification to a bandwidth of 35 MHz (G = +2) in addition to the low differential
  gain and phase errors. This performance is achieved whether
  driving one or two back terminated 75 Ω cables, with a low
  power supply current of 16.5 mA. Furthermore, the AD811 is
  specified over a power supply range of ±4.5 V to ±18 V.
AD811芯片资料
评论(0)
发评论
下载排行榜
