1.5SMCJ6.8A(CA) - 1.5SMCJ440A(CA表面贴装瞬态电压抑制器
消耗积分:0 | 格式:pdf | 大小:620KB | 2017-10-17
王君越
分享资料个
1500W 6.8V -440V
  Glass Passivated Die Construction Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Features 2. Thermal Resistance junction to Lead. NOTES:1. Non-repetitive current pulse ,per Fig. 3 and derated above TA=25℃ per Fig. 1. 3. 8.3ms single half-wave duty cycle=4 pulses per minutes maximum (uni-directional units only)。 ! ! ! ! Case :DO-214AB(SMC) See Page 2 Mechanical Data Marking: Date Code and Marking Code Weight: 0.21 grams (approximate) ! ! ! ! Terminals : Solder plated , solderable per MIL-STD-750, method 2026 Classification Rating 94V-O ! Plastic Case Material has UL Flammability
评论(0)
发评论
下载排行榜
