DSP应用与实例
消耗积分:0 | 格式:rar | 大小:0.41 MB | 2017-10-23
分享资料个
  Modems (Modulator/Demodulator) are widely used to transmit and receive digital
  data using analog modulation over the Plain Old Telephone Service (POTS) network
  as well as private lines. Although the data to be transmitted is digital, the telephone
  channel is designed to carry voice signals having a bandwidth of approximately 300
  to 3300Hz. The telephone transmission channel suffers from delay distortion, noise,
  crosstalk, impedance mismatches, near-end and far-end echoes, and other
  imperfections. While certain levels of these signal degradations are perfectly
  acceptable for voice communication, they can cause high error rates in digital data
  transmission. The fundamental purpose of the transmitter portion of the modem is
  to prepare the digital data for transmission over the analog voice line. The purpose
  of the receiver portion of the modem is to receive the signal which contains the
  analog representation of the data , and reconstruct the original digital data at an
  acceptable error rate. High performance modems make use of digital techniques to
  perform such functions as modulation, demodulation, error detection and correction,
  equalization, and echo cancellation.
  A block diagram of an ordinary telephone channel (often referred to as plain old
  telephone service – or POTS) is shown in Figure 9.1. Most voiceband telephone
  connections involve several connections through the telephone network. The 2-wire
  twisted pair subscriber line available at most sites is generally converted to a 4-wire
  signal at the telephone central office: two wires for transmit, and two wires for
  receive. The signal is converted back to a 2-wire signal at the far-end subscriber
  line. The 2- to 4-wire interface is implemented with a circuit called a hybrid. The
  hybrid intentionally inserts impedance mismatches to prevent oscillations on the 4-
  wire trunk line. The mismatch forces a portion of the transmitted signal to be
  reflected or echoed back to the transmitter. This echo can corrupt data the
  transmitter receives from the far-end modem.
  Half-duplex modems are capable of passing signals in either direction on a 2-wire
  line, but not simultaneously. Full-duplex modems operate on a 2-wire line and can
  transmit and receive data simultaneously. Full-duplex operation requires the ability
  to separate a receive signal from the reflection (echo) of the transmitted signal. This
  is accomplished by assigning the signals in the two directions different frequency
  bands separated by filtering, or by echo cancelling in which a locally synthesized
  replica of the reflected transmitted signal is subtracted from the composite receive
  signa
DSP应用与实例
评论(0)
发评论
下载排行榜
