LC2MOS四路SPST开关adg441/adg442/adg444数据表
消耗积分:0 | 格式:rar | 大小:0.30 MB | 2017-10-24
分享资料个
  The ADG441, ADG442, and ADG444 are monolithic CMOS devices that comprise of four independently selectable switches. They are designed on an enhanced LC2MOS process that provides low power dissipation yet gives high switching speed and low on resistance.
  The on resistance profile is very flat over the full analog input range, which ensures good linearity and low distortion when switching audio signals. High switching speed also makes the parts suitable for video signal switching. CMOS construction ensures ultralow power dissipation, making the parts ideally suited for portable and battery-powered instruments. The ADG441, ADG442, and ADG444 contain four independent SPST switches. Each switch of the ADG441 and ADG444 turns on when a logic low is applied to the appropriate control input. The ADG442 switches are turned on with logic high on the appropriate control input. The ADG441 and ADG444 switches differ in that the ADG444 requires a 5 V logic power supply that is applied to the VL pin. The ADG441 and ADG442 do not have a VL pin, the logic power supply is generated internally by an on-chip voltage generator.
评论(0)
发评论
下载排行榜
