The ADG841-KGD is a low voltage CMOS device containing a single-pole, single-throw (SPST) switch. The ADG841-KGD is closed for a Logic 1 input. The device offers ultralow on resistance of less than 0.48 Ω over the full temperature range. The ADG841-KGD is fully specified for 3.3 V, 2.5 V, and 1.8 V supply operation.
Each switch conducts equally well in both directions when on, and has an input signal range that extends to the supplies.
Additional application and technical information can be found in the ADG841 data sheet.
