用保证金控制和非易失性故障记录超级音序器ADM1166数据表
消耗积分:0 | 格式:rar | 大小:0.59 MB | 2017-10-25
分享资料个
  The ADM1166 Super Sequencer® is a configurable supervisory/ sequencing device that offers a single-chip solution for supply monitoring and sequencing in multiple-supply systems. In addition to these functions, the ADM1166 integrates a 12-bit ADC and six 8-bit voltage output DACs. These circuits can be used to implement a closed-loop margining system that enables supply adjustment by altering either the feedback node or reference of a dc-to-dc converter using the DAC outputs.
  Supply margining can be performed with a minimum of external components. The margining loop can be used for in-circuit testing of a board during production (for example, to verify board func-tionality at −5% of nominal supplies), or it can be used dynamically to accurately control the output voltage of a dc-to-dc converter.
  For more information about the ADM1166 register map, refer to the AN-698 Application Note.
评论(0)
发评论
下载排行榜
