SOT-23塑料封装晶体管
消耗积分:1 | 格式:rar | 大小:0.6 MB | 2017-12-07
分享资料个
  S8050  TRANSISTOR (NPN) SOT-23
FEATURES
z Complimentary to S8550 1. BASE
z Collector Current: IC=0.5A 2. EMITTER
MARKING: J3Y 3. COLLECTOR
MAXIMUM RATINGS (Ta=25 unless otherwise noted)
  Symbol Parameter Value Unit
  VCBO Collector-Base Voltage 40 V
  VCEO Collector-Emitter Voltage 25 V
  VEBO Emitter-Base Voltage 5 V
  IC Collector Current -Continuous 0.5 A
  PC Collector Dissipation 0.3 W
  RΘJA Thermal Resistance from Junction to Ambient 417 ℃/W
  Tj Junction Temperature 150
  Tstg Storage Temperature -55-150
ELECTRICAL CHARACTERISTICS (Ta=25 unless otherwise specified)
  Parameter     Symbol Test conditions Min Typ   Max Unit
  Collector-base breakdown voltage   V(BR)CBO IC= 100μA, IE=0 40       V
  Collector-emitter breakdown voltage   V(BR)CEO IC=1mA, IB=0 25       V
  Emitter-base breakdown voltage     V(BR)EBO IE=100μA, IC=0 5       V
  Collector cut-off current     ICBO VCB=40 V , IE=0       0.1 μA
  Collector cut-off current     ICEO VCB=20V , I E=0       0.1 μA
  Emitter cut-off current     IEBO VEB= 5V , IC=0       0.1 μA
        hFE(1) VCE=1V, I C= 50mA 120     400
  DC current gain
      hFE(2) VCE=1V, I C= 500mA 50
  Collector-emitter saturation voltage   VCE(sat) I=500 mA, IB= 50mA       0.6 V
  Base-emitter saturation voltage     VBE(sat) IC=500 mA, IB= 50mA       1.2 V
  Transition frequency     fT VCE=6V, I C= 20mA 150       MHz
      f=30MHz
CLASSIFICATION OF hFE(1)
  Rank   L H       J
  Range 120-200   200-350     300-400
SOT-23塑料封装晶体管
评论(0)
发评论
下载排行榜
