TASM5 BORLAND公司开发的汇编编译器..rar
消耗积分:0 | 格式:rar | 大小:4198 | 2010-02-24
王秀兰
分享资料个
TASM5.  BORLAND公司开发的汇编编译器
                                 TSM_RDME.TXT
                               TURBO ASSEMBLER
                 Welcome to Borland Turbo Assembler and Tools 5.0
TABLE OF CONTENTS
1. Installation
2. New Features
3. Assembling and Linking with TASM 5.0
4. TASM utilities
5. Important Information
   a) Object File Format
   b) Out of Memory and MAKESWAP
   c) Make under Windows NT
   d) Creating 16-bit import libraries from .DEF files
   e) Resource compilers: 32-bit command-line versions
1. Installation
For details on installing Turbo Assembler and Tools 5.0, see the file
TSM_INST.TXT
2. New Features
New TASM 5.0 features:
  - Enhanced MASM compatibility
  - TASM32.EXE Thunk Compiler compatibility for Windows 95 flat thunking.
New Turbo Debugger 5.0 features:
  - Dual monitor support under Win95 (TDW: -do, TD32: -vd)
  - Debugger support for new C++ language constructs (bool, namespaces, etc.)
  - 16-bit debugging support under Windows NT with TDW.EXE
3. Assembling and linking with TASM 5.0
The TASM 5.0 package includes three different assemblers:
  TASM.EXE           16-bit real-mode assembler
  TASMX.EXE          16-bit protected-mode assembler
  TASM32.EXE         32-bit protected-mode assembler
All three assemblers are capable of producing both 16- and 32-bit
object files, depending on the directives contained in your assembler
source files. If you produce a 16-bit object file, then you must use
the 16-bit linker (TLINK.EXE) to link your application. If you produce
a 32-bit object file, then you must use the 32-bit linker (TLINK32.EXE)
TASM.EXE is a real-mode assembler, meaning that it is capable of using
only the lower 640K of memory addressable by DOS. If you're assembling
larger applications, use either TASMX.EXE or TASM32.EXE. Both of these
assemblers use the DPMI server to take advantage of extended memory.
The biggest difference between the three assemblers is the type of
debug information they produce when you assemble your source files with
the /zi command-line option. Both TASM.EXE and TASMX.EXE produce
only 16-bit debug information. TASM32.EXE produces only 32-bit debug
information. If you plan to use Turbo Debugger to debug your assembler
application, then you must assemble 16-bit files with either TASM.EXE
or TASMX.EXE. To produce 32-bit debug information, then you must assemble
your files with TASM32.EXE.
4. TASM utilities
TASM 5.0 ships with several debuggers and utilities to help you create and
debug your assembly language programs.  For more information on Turbo
Debugger and the tools provided with TASM, refer to the text files located
in the DOC subdirectory located under your main TASM directory.
Turbo Assembler generates object modules (.OBJ files) which conform to the
Intel OMF (Object Module Format) specification.  In addition, the provided
tools (such as TLINK32 and TLIB) and libraries accept only this format;
there is no support in the linker or librarian for COFF object modules
produced by Microsoft C tools.
If you get "Out of Memory" errors from DOS when running the command-line
tools, create a swap file with the MAKESWAP utility.  (Note that this
applies to DOS only, not to DOS boxes opened under Windows.) MAKESWAP
takes the size of the file to create in KBytes, for example:
    MAKESWAP 12000
will create a 12MB swap file in the current directory called EDPMI.SWP for
use by Borland command line tools.  To enable the swap file, use the
DPMI32 environment variable by issuing the following command at the DOS
prompt:
    set DPMI32=SWAPFILE \EDPMI.SWP
If you encounter difficulties running MAKE under Windows NT, try running
MAKER instead.
Use the /o IMPLIB switch when you are creating 16-bit import libraries
from .DEF files.  This prevents IMPLIB from generating extensions for
import entry module names.
The 32-bit command-line resource compilers (br*.exe) that ship with TASM
5.0 do not run under 16-bit environments of DOS or Windows 3.1; you must
run these 32-bit tools from the DOS boxes in Windows 95 or Windows NT.  If
do not have access to Win95 or NT, you must use the 16-bit resource
compilers (such as the ones shipped with TASM 4.0 or Borland C++ 4.5) to
compile resources from the command line.
/********************************* END OF FILE ****************************/
评论(0)
发评论
下载排行榜
