Bat 文件编译器
消耗积分:0 | 格式:rar | 大小:31 | 2010-05-06
王敏
分享资料个
Bat 文件编译器汇编语言源程序代码:; BAT2EXEC.COM - a batch file compiler
; BAT2EXEC filename
; Revision History:
; Version 1.0 Initial Release  PC Magazine Vol 9 Num 14
  code segment
  assume cs:code
  org 2ch
env_segment dw ?   ;Word containing the segment
      ;  of the program's env. block.
  org 80h
command_tail db ?   ;Offset of the command tail.
  org 100h
main:  jmp initialize
program  db 13,10,"BAT2EXEC 1.0 "
copyright db "(c) 1990 Ziff Communications Co.",10,13
author  db "PC Magazine ",254," Douglas Boling"
  db 10,13,"$",1Ah
评论(0)
发评论
下载排行榜
