TLC7135,pdf (4 1/2-Digit Preci
消耗积分:0 | 格式:rar | 大小:449 | 2010-06-03
远不及你
分享资料个
The ICL7135C and TLC7135C converters are manufactured with Texas Instruments highly efficient CMOS technology. These 4 1/2-digit, dual-slope-integrating, analog-to-digital converters (ADCs) are designed to provide interfaces to both a microprocessor and a visual display. The digit-drive outputs D1 through D4 and multiplexed binary-coded-decimal outputs B1, B2, B4, and B8 provide an interface for LED or LCD decoder/drivers as well as microprocessors.
The ICL7135C and TLC7135C offer 50-ppm (one part in 20,000) resolution with a maximum linearity error of one count. The zero error is less than 10 µV and zero drift is less than 0.5 µV/°C. Source-impedance errors are minimized by low input current (less than 10 pA).
评论(1)
发评论
xidaozheng 2022-07-13
0 回复 举报
就是个英文手册 收起回复
下载排行榜
全部1条评论
