ADS826ADS823pdf( 10-Bit 60M
消耗积分:0 | 格式:rar | 大小:496 | 2010-06-07
孙成红
分享资料个
The ADS823 and ADS826 are pipeline, CMOS Analog-to-Digital Converters (ADCs) that operate from a single +5V power supply. These converters provide excellent performance with a single-ended input and can be operated with a differential input for added spurious performance. These high-performance converters include a 10-bit quantizer, high-bandwidth track-and-hold, and a high-accuracy internal reference. They also allow for disabling the internal reference and utilizing external references. This external reference option provides excellent gain and offset matching when used in multi-channel applications or in applications where full-scale range adjustment is required.
The ADS823 and ADS826 employ digital error correction techniques to provide excellent differential linearity for demanding imaging applications.
评论(0)
发评论
下载排行榜
