TLV5637,pdf(2.7V To 5.5V Low-P
消耗积分:0 | 格式:rar | 大小:418 | 2010-06-08
王兰
分享资料个
The TLV5637 is a dual 10-bit voltage output DAC with a flexible 3-wire serial interface. The serial interface allows glueless interface to TMS320 and SPI™, QSPI™, and Microwire™ serial ports. It is programmed with a 16-bit serial string containing 2 control and 10 data bits.
The resistor string output voltage is buffered by a x2 gain rail-to-rail output buffer. The buffer features a Class AB output stage to improve stability and reduce settling time. The programmable settling time of the DAC allows the designer to optimize speed versus power dissipation. With its on-chip programmable precision voltage reference, the TLV5637 simplifies overall system design.
Because of its ability to source up to 1mA, the reference can also be used as a system reference.
评论(0)
发评论
下载排行榜
