uaf42通用低通滤波器
消耗积分:0 | 格式:rar | 大小:293 | 2010-08-27
分享资料个
  The UAF42 is a universal active filter that can be
  – Low-Pass, High-Pass configured for a wide range of low-pass, high-pass,
  – Band-Pass, Band-Reject and band-pass filters. It uses a classic state-variable analog architecture with an inverting amplifier and two
  · SIMPLE DESIGN PROCEDURE integrators. The integrators include on-chip 1000pF
  · ACCURATE FREQUENCY AND Q: capacitors trimmed to 0.5%. This architecture solves
  – Includes On-Chip 1000pF ±0.5% Capacitors one of the most difficult problems of active filter
  design—obtaining tight tolerance, low-loss capacitors.
  A DOS-compatible filter design program allows easy
  · TEST EQUIPMENT implementation of many filter types, such as
  · COMMUNICATIONS EQUIPMENT Butterworth, Bessel, and Chebyshev. A fourth, · MEDICAL INSTRUMENTATION uncommitted FET-input op amp (identical to the other three) can be used to form additional stages, or for
  · DATA ACQUISITION SYSTEMS special filters such as band-reject and Inverse
  · MONOLITHIC REPLACEMENT FOR UAF41 Chebyshev.
  The classical topology of the UAF42 forms a
  time-continuous filter, free from the anomalies and
  switching noise associated with switched-capacitor
  filter types.
  The UAF42 is available in 14-pin plastic DIP and
  SOIC-16 surface-mount packages, specified for the
  –25°C to +85°C temperature range.
评论(2)
发评论
独自玩耍的座头鲸 2018-04-16
0 回复 举报
可以ma 收起回复
yangchao1990 2011-08-21
0 回复 举报
技术手册!!! 收起回复
下载排行榜
全部2条评论
