UCC5686,UCC5687,df(27-Line 3V
消耗积分:0 | 格式:rar | 大小:282 | 2010-09-09
分享资料个
The UCC5686 is a twenty-seven line active terminator for low-voltage-differential (LVD) SCSI networks. This LVD SCSI-only design allows the user to reach peak bus performance, while reducing system cost. The device is designed as an active Y-terminator to improve the frequency response of the LVD SCSI Bus. Designed with a 2-pF (typical) channel capacitance, the UCC5686 allows for minimal bus loading for a maximum number of peripherals. With the UCC5686, the designer is able to comply with the Ultra2, Ultra3, Ultra160, and Ultra320 SCSI specifications. The UCC5686 also provides a much-needed system migration path for the ever improving SCSI system standards.
This device is available in the 64-pin low-profile QFP package for ease of layout use.
评论(0)
发评论
下载排行榜
