PCI9050 pdf datasheet (Bus Tar
消耗积分:5 | 格式:rar | 大小:444 | 2008-10-13
33391
分享资料个
As PCI gains momentum as the preeminent backplane standard, suppliers of
add-in cards of all types are rushing to get PCI versions to market. Continuing
its drive to provide single-chip PCI interfaces for every market, PLX offers
designers its PCI 9050 Bus Target Interface Chip for low cost adapters.
The PCI 9050 provides a compact, high performance PCI bus target (slave)
interface for adapter boards. It enables rapid, low cost conversion of Industry
Standard Architecture (ISA) adapters to the PCI bus. The PCI 9050 accelerates I/O
data movements on adapter boards from ISA°Os nominal bus speed of 8
MHz,
5 Mbytes/second to PCI°Os 33 MHz, 132 Mbytes/second data transfer capability
For designers looking for a simple and painless way to convert their ISA
adapters, PLX offers the PCI 9050 RDK! It includes a PCI board designed with the
PCI 9050 chip, I/O daughter card connector for standard or custom functions, a
breadboard area, test headers, and a piggyback ISA slot that enables existing ISA
boards to be plugged into the PCI 9050 for software and hardware implementa-
tion. The PCI 9050RDK also includes a set of development software tools, includ-
ing PLXMon? for PCI bus monitoring and debug, and example serial/modem
device drivers for Windows 95.?
评论(0)
发评论
下载排行榜
