PCI9030 pdf datasheet
消耗积分:10 | 格式:rar | 大小:454 | 2008-10-13
哈哈哈
分享资料个
The PCI 9030 PCI SMARTarget™ I/O Accelerator provides an array of features that define a performance, flexibility and simplicity in PCI designs. A 32-bit, 33MHz PCI v.2.2-compliant device with burst transfers up to 132Mbytes/sec, the PCI 9030 delivers high performance to new PCI-based adapters and those migrating from legacy designs. The device's 60MHz local bus, 3V/5V operation, and programmable general-purpose I/Os (GPIOs) and chip selects bring unprecedented flexibility to a wide variety of memory and I/O devices. The combination of these features make adapters used in high-bandwidth applications, such as telecommunications and data communications interface cards, easier than ever to design. The PCI 9030 is offered in a 26 x 26mm 176-pin PQFP or 12 x 12mm 180-ball µBGA. This device is available in leaded and lead-free packaging.
评论(0)
发评论
下载排行榜
