AM457 pdf datasheet (Precision
消耗积分:3 | 格式:rar | 大小:555 | 2008-10-15
刘洋
分享资料个
AM457 is a high-precision integrated amplifier which
has been developed to condition signals from small
differential input voltages within a range of a few
millivolts (±5 to ±100mV FS). The chief component
of the IC is a highly accurate, low-noise amplifier
circuit (AMP). An additional integrated operational
amplifier (OP) can be used to supply a sensing
element with current or record temperature for sensor
bridges powered by voltage, for example. The entire
system (sensing element plus amplifier) is monitored
by the integrated diagnostic unit which logs any
sensing element errors or defects, system
undervoltage, AMP overloads and excessive
temperature. The various function groups are not
mutually dependent on one another; the AMP can be
operated independently of the OP, for example. The
functionality of both component groups (AMP and
OP) is autonomous with regard to the diagnostic unit.
AM457 is a combination of high-impedance precision
amplifier, additional OP and extensive diagnostic unit,
enabling a self-monitoring sensor system to be
assembled using very few components.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
