SA58643 pdf datasheet(Single-P
消耗积分:3 | 格式:rar | 大小:167 | 2008-10-18
分享资料个
The SA58643 is a wideband RF switch fabricated in BiCMOS technology and incorporating on-chip CMOS/TTL compatible drivers. Its primary function is to switch signals in the frequency range DC to 1 GHz from one 50 Ohm channel to another. The switch is activated by a CMOS/TTL compatible signal applied to the enable channel 1 pin (ENCH1).
The extremely low current consumption
评论(0)
发评论
下载排行榜
