NCP1586 Low Voltage Synchronous Buck Controller The NCP1586 is a low cost PWM controller designed to operate from a 5 V or 12 V supply. This device is capable of producing an output voltage as low as 0.8 V. This 8−pin device provides an optimal level of integration to reduce size and cost of the power supply. The NCP1586 provides a 1 A gate driver design and an internally set 275 kHz oscillator. In addition to the 1 A gate drive capability, other efficiency enhancing features of the gate driver include adaptive non−overlap circuitry. The NCP1586 also incorporates an externally compensated error amplifier and a capacitor programmable soft−start function. Protection features include programmable short circuit protection and under voltage lockout (UVLO). The NCP1586 comes in an 8−pin SOIC package. Features • Input Voltage Range from 4.5 to 13.2 V • 275 kHz Internal Oscillator • Boost Pin Operates to 26.5 V • Voltage Mode PWM Control • 0.8 V ±1.0 % Internal Reference Voltage • Adjustable Output Voltage • Capacitor Programmable Soft−Start • Internal 1 A Gate Drivers • 80% Max Duty Cycle • Input Under Voltage Lockout • Programmable Current Limit • This is a Pb−Free Device Applications • Graphics Cards • Desktop Computers • Servers / Networking • DSP & FPGA Power Supply • DC−DC Regulator Modules
