OPA111 pdf datasheet (Low Nois
消耗积分:3 | 格式:rar | 大小:333 | 2008-11-23
分享资料个
The OPA111 is a precision monolithic dielectrically
isolated FET (Difet ®) operational amplifier. Outstanding
performance characteristics allow its use in the
most critical instrumentation applications.
Noise, bias current, voltage offset, drift, open-loop
gain, common-mode rejection, and power supply rejection
are superior to BIFET® amplifiers.
Very low bias current is obtained by dielectric isolation
with on-chip guarding.
Laser trimming of thin-film resistors gives very low
offset and drift. Extremely low noise is achieved with
patented circuit design techniques. A new cascode
design allows high precision input specifications and
reduced susceptibility to flicker noise.
Standard 741 pin configuration allows upgrading of
existing designs to higher performance levels.
评论(0)
发评论
下载排行榜
