开源硬件-PMP40183.4-适用于快速充电 UFP 应用的 45W USB Type-C™ PD DFP 适配器 PCB layout 设计
消耗积分:0 | 格式:pdf | 大小:1.32MB | 2020-05-21
李中宏
分享资料个
The PMP40183 reference design is a fast charger solution with secondary-side regulation using UCC28740 which provides Constant-Voltage Constant-Current. The design supports maximum 15V/3A PD 3.0 standard and also 6.2V-11V/4A output power level. This output performance will enable fast charge (...)
评论(0)
发评论
下载排行榜
