The mPD753012A, 753016A, and 753017A are members of NEC’s new 75XL series of 4-bit single-chip microcontrollers. This product has a higher ROM capacity and more sophisticated CPU than the existing mPD753xxB, can operate at high speeds on a voltage as low as 1.8 V, and is provided with an LCD controller/driver. In addition, a super small plastic TQFP (12 x 12 mm), which makes a substantial contribution to miniaturization of the LCD panel, is also available. FEATURES • On-chip carrier generator for infrared remote controller (TM1, TM2) • LCD controller/driver : Can display up to 128 segments (32 segments x 4 common) · Common pins : 4 lines · Segment pins : 32 lines (of which 8 can be used as general-purpose output pins) • Instruction execution time (variable) · 0.95 ms/1.91 ms/3.81 ms/15.3 ms (main system clock; at fX = 4.19 MHz) · 0.67 ms/1.33 ms/2.67 ms/10.7 ms (main system clock; at fX = 6.0 MHz) · 122 ms (subsystem clock; at fXT = 32.768 kHz) • Program memory (ROM) : mPD753012: 12288 x 8 bits mPD753016: 16384 x 8 bits mPD753017: 24576 x 8 bits • Data memory (RAM) : 1024 x 4 bits • Five channels of timers · 8-bit basic interval timer/watchdog timer · Watch timer
