MPEG-4音频参考程序
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-16
xymbmcu
分享资料个
MPEG-4音频参考程序:# MPEG-4 Audio VM
# makefile (requires GNU make)
# $Id: makefile,v 1.60 1999/07/26 13:17:56 purnhage Exp $
# Authors:
# BG    Bernhard Grill, Uni Erlangen
# HP    Heiko Purnhagen, Uni Hannover
# BT    Bodo Teichmann, FhG/IIS
# SE Sebastien Etienne, CCETT Rennes
# Changes:
# 11-jun-96   BG    basic concept
# 13-jun-96   HP    first version
# 14-jun-96   HP    test stuff added
# 19-jun-96   HP    indiline.a added
# 20-jun-96   HP    modifications proposed by BG
# 28-jun-96   HP    fixed COPTS bug
# 04-jul-96   HP    restructured makefile, fixed CFLAGS/LIBS bug
# 04-jul-96   HP    included "pre-linked object file directory" by BG
# 05-jul-96   HP    fixed override CFLAGS/LIBS
# 20-aug-96   BG    OS2 modifications
# 26-aug-96   HP    removed PLOBJS, adapted to vm directory structure
# 26-aug-96   HP    CVS
# 13-sep-96   HP    removed -O option for Linux g++
# 25-oct-96   HP    adapted makefile options / added makefile.cfg
# 01-nov-96   HP    added "depend" target
# 03-dec-96   HP    added comment re. include dependency files
#                   added library dependency rules
# 21-jan-97   HP    added audio i/o module
# 31-jan-97   HP    seperated encoder and  -g directories
# 05-feb-97   HP    added COMLIBS
# 12-feb-97   HP    make CFLAGS and LDFLAGS values passed on and evaluated
# 14-feb-97   HP    included PICOLA speed control (by Panasonic)
# 11-mar-97   HP    included PICOLA source code
# 21-mar-97   BT    fixed CC and IRIX things, platform autodetect
# 26-mar-97   CCETT included G729  -g source code
# 20-may-97   HP    clean up
# 22-may-97   HP    added DEBUGPLOT (substitutes PLOTMTV)
# 03-jun-97   HP    disabled DEBUGPLOT as default
# 07-nov-97   HP    merged with FhG mods
# 08-apr-98   HP    added OSF platform
# 09-apr-98   HP/CF added rm before ar when making libs
# 13-oct-98   HP    improved platform detection
# 02-dec-98   HP/nn merged version-dependent directory stuff by FhG
# 11-jan-99   HP    linux_gcc
# 20-jan-99   HP    cleaned up platform dependency stuff and CFLAGS defaults
# 21-jan-99   HP    audio.c & austream.c
# 22-jan-99   HP    USE_AFSP
# 23-apr-99   HP    updated, some files renamed for IM1-compability
# 28-apr-99   HP    using AFSP_INCLUDE_PATH / AFSP_LIBRARY_PATH ...
# Notes:
# This makefile provides automatic handling of different system
# platforms. Therefore it is required to set the environment
# variable SYSTEM_NAME according to the actual platform.
# Currently, these platforms are supported:
#   IRIX
#   Linux
#   Solaris
#   ... and most other UNIX platforms ...
# If CFLAGS or LDFLAGS are changed for a subsequent invocation of make,
# object files and binaries are NOT remade automatically with the new
# options! Use "make clean" first ...
# To make mp4auenc and mp4audec, type:
#   make all
# To allow make running e.g. 4 jobs at once, type:
#   make MFLAGS=-j4
# On most platforms, the default compiler is g++. To use the platform's
# native compiler (e.g. cc) instead, type:
#   make MAKE_CC=native
# and to use gcc, type:
#   make MAKE_CC=gnu
# BG: OS2 fix
ifeq "$(SYSTEM_NAME)" "OS2"
SHELL = /bin/sh
export SHELL
endif
# HP 981013
ifeq "$(SYSTEM_NAME)" ""
ifeq "$(OSTYPE)" ""
SYSTEM_NAME = $(shell uname -s)
else
ifeq "$(OSTYPE)" "linux"
SYSTEM_NAME = Linux
endif
ifeq "$(OSTYPE)" "linux-gnu"
SYSTEM_NAME = Linux
endif
ifeq "$(OSTYPE)" "solaris"
SYSTEM_NAME = Solaris
endif
ifeq "$(OSTYPE)" "iris4d"
SYSTEM_NAME = IRIX
endif
ifeq "$(OSTYPE)" "sunos4"
SYSTEM_NAME = SunOS
endif
ifeq "$(OSTYPE)" "osf1"
SYSTEM_NAME = OSF
endif
ifeq "$(OSTYPE)" "cygwin32"
SYSTEM_NAME = cdk
endif
endif
endif
include error:\ SYSTEM_NAME\ environment\ variable\ not\ defined\ !!!
include Options:\ SunOS\ IRIX\ Linux\ OS2\ Solaris\ OSF\ cdk\ !!!
endif
ifeq "$(MAKELEVEL)" "0"
评论(0)
发评论
下载排行榜
