CD4514/CD4515 pdf datasheet
消耗积分:10 | 格式:rar | 大小:333 | 2008-12-17
分享资料个
The CD4514 and CD4515 are 4-to-16 line decoders
with latched inputs implemented with complementary MOS
(CMOS) circuits constructed with N- and P-channel
enhancement mode transistors. These circuits are primarily
used in decoding applications where low power dissipation
and/or high noise immunity is required.
The CD4514BC (output active high option) presents a logical
“1” at the selected output, whereas the CD4515BC presents
a logical “0” at the selected output. The input latches
are R–S type flip-flops, which hold the last input data presented
prior to the strobe transition from “1” to “0”. This
input data is decoded and the corresponding output is activated.
An output inhibit line is also available.
评论(0)
发评论
下载排行榜
