OPA627/OPA637 pdf datasheet (P
消耗积分:10 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The OPA627 and OPA637 Difet operational amplifiers
provide a new level of performance in a precision
FET op amp. When compared to the popular OPA111
op amp, the OPA627/637 has lower noise, lower offset
voltage, and much higher speed. It is useful in a broad
range of precision and high speed analog circuitry.
The OPA627/637 is fabricated on a high-speed, dielectrically-
isolated complementary NPN/PNP process. It
operates over a wide range of power supply voltage—
±4.5V to ±18V. Laser-trimmed Difet input circuitry
provides high accuracy and low-noise performance
comparable with the best bipolar-input op amps.
评论(0)
发评论
下载排行榜
