OPA234、OPA2234、OPA4234 pdf dat
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-18
山中老虎
分享资料个
The OPA234 series low cost op amps are ideal for
single supply, low voltage, low power applications. The
series provides lower quiescent current than older
“1013”-type products and comes in current industrystandard
packages and pinouts. The combination of low
offset voltage, high common-mode rejection, high power
supply rejection, and a wide supply range provides
excellent accuracy and versatility. Single, dual, and
quad versions have identical specifications for maximum
design flexibility. These general purpose op amps
are ideal for portable and battery powered applications.
OPA234 series op amps operate from either single or
dual supplies. In single supply operation, the input common-
mode range extends below ground and the output
can swing to within 50mV of ground. Excellent phase
margin makes the OPA234 series ideal for demanding
applications, including high load capacitance. Dual and
quad designs feature completely independent circuitry
for lowest crosstalk and freedom from interaction.
Single version packages are 8-Pin DIP, SO-8 surfacemount,
and a space-saving MSOP-8 surface-mount.
Dual packages are 8-Pin DIP and SO-8 surface-mount.
Quad packages are 14-Pin DIP and SO-14 surfacemount.
All are specified for –40°C to +85°C operation.
评论(0)
发评论
下载排行榜
