OPA130、OPA2130、OPA4130 pdf dat
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The OPA130 series of FET-input op amps combine
precision dc performance with low quiescent current.
Single, dual, and quad versions have identical specifications
for maximum design flexibility. They are ideal
for general-purpose, portable, and battery operated
applications, especially with high source impedance.
OPA130 op amps are easy to use and free from phase
inversion and overload problems often found in
common FET-input op amps. Input cascode circuitry
provides excellent common-mode rejection and
maintains low input bias current over its wide input
voltage range. OPA130 series op amps are stable in
unity gain and provide excellent dynamic behavior
over a wide range of load conditions, including high
load capacitance. Dual and quad designs feature
completely independent circuitry for lowest crosstalk
and freedom from interaction, even when overdriven
or overloaded.
Single and dual versions are available in 8-pin DIP
and SO-8 surface-mount packages. Quad is
available in 14-pin DIP and SO-14 surface-mount
packages. All are specified for –40°C to +85°C
operation.
评论(0)
发评论
下载排行榜
