CA3450 pdf datasheet(220MHz, V
消耗积分:3 | 格式:rar | 大小:323 | 2008-12-22
分享资料个
The CA3450 is a large signal video line driver and high
speed operational amplifier capable of driving 50Ω
transmission lines and flash A/Ds. The uncompensated unity
gain crossing occurs at 230MHz without load. It can operate
at dual or single supplies of ±7.25V or 14.5V, respectively.
The CA3450 can be compensated with a single capacitor
network. It has output drive capability of 75mA SINK or
SOURCE. The CA3450 is capable of driving Flash A/Ds in
video or high speed instrumentation (accurate) applications
with bandwidth up to 10MHz. Offset voltage nulling terminals
are also available.
评论(0)
发评论
下载排行榜
