基于KIT10XS4200EVBEPower Switch的参考设计
消耗积分:3 | 格式:pdf | 大小:127.15KB | 2021-01-10
王兰
分享资料个
说明
  • KIT10XS4200EVBE, Extreme Switch Evaluation Board demonstrates the capability of the MC10XS4200 as a 24V dual high side switch product, that provides integrated control along with a large number of protective and diagnostic functions. This product has been designed for truck, bus and industrial applications. The low RDS(ON) channels (<10 m-Ohm) control different load types: bulb lamps, solenoids, or DC motors. Control, device configuration and diagnostics are performed through a 16-bit SPI interface, allowing easy integration into existing applications
主要特色
  • 输入电压
    6至58 V
  • 衍生元素数量
    2
评论(0)
发评论
下载排行榜
