基于MIKROE-3350调制调解器的参考设计
消耗积分:2 | 格式:pdf | 大小:155.45KB | 2021-01-15
从未拥有
分享资料个
说明
  • MIKROE-3350, 4G LTE-AT&T Click Board is an LTE Cat 1/UMTS multi mode cellular network solution, featuring the compact LARA-R2 series modem. This module supports up to four LTE bands and up to two UMTS bands. It also features a full range of options for the high speed cellular networking and communication, such as the network indication, full embedded TCP/UDP stack, HTTP and HTTPS transfer protocols, IPv4/IPv6 dual-stack support, secondary antenna for the RX diversity, antenna detection, jamming signal detection, embedded TLS 1.2 protocol for the improved security and more
主要特色
  • 频道数
    4
评论(0)
发评论
下载排行榜
