The HA-5195 is a operational amplifier featuring a combination of speed, precision, and bandwidth. Employing monolithic bipolar construction coupled with Dielectric Isolation, this device is capable of delivering 200V/μs slew rate with a settling time of 70ns (0.1%, 5V output step). This truly differential amplifier is designed to operate at gains ≥ 5 without the need for external compensation. Other outstanding features are 150MHz gain bandwidth product and 6.5MHz full power bandwidth. In addition to these dynamic characteristics, this amplifier also has excellent input characteristics such as 3mV offset voltage and 6.0nV/√Hz input voltage noise at 1kHz. With 200V/μs slew rate and 70ns settling time, the HA-5195 is an ideal output amplifier for accurate, high speed D/A converters or the main components in high speed sample/hold circuits. The 5195 is also ideally suited for a variety of pulse and wideband video amplifiers. Please refer to Application Notes AN525 and AN526 for some of these application designs.
