High Speed, Low Power, Analog-to-Digital Converter Evaluation Kit
* Full featured evaluation board for the HMCAD1511, and HMCAD1520 ADCs
* Simple USB computer interface
* Single-ended SMA connectors for clock inputs and analog inputs
* ADC obtains power from Xilinx SP-601 FMC connector
* Eval01-HMCAD1511/EVAL01-HMCAD1520 EZ-Board®
* SP-601 Xilinx development board with EasyStack
* EasySuite software and User Manual: https://www.analog.com/en/design-center/evaluation-hardware-and-software/a-d-converter-evaluation-software.html
* Clock source
* Signal source
* PC capable of running EasySuite software
This user guide describes the physical components of the EVAL01-HMCAD1511/EVAL01-HMCAD1520 EZ-Boards®. These boards are a part of the EKIT01-HMCAD1511/EKIT01-HMCAD1520 evaluation kits. The kits consist of an EZ-Board field-programmable gate array (FPGA) mezzanine card (FMC) daughter board, a Xilinx® FMC SP601 development mother board, and the EasySuite software. Refer to the EasySuite software user guide for installation of the EasySuite software. The EasyStack firmware is loaded on the Xilinx development board, which enables configuration of the analog-to-digital converter (ADC) and capturing of data from the ADC. The EKIT01-HMCAD1511/EKIT01-HMCAD1520 features power monitoring and supply voltage adjustment.
Figure 1. EVAL01-HMCAD15XX Hittite EasyBoard(TM)
The quality of the input signal is the most important criterion to obtain accurate measurement results. The user must also take the following into consideration:
The input network of the EZ-Board is configured with an ac-coupled balun. This balun converts the single-ended input to a differential input for the ADC (see Figure 3).
The clock inputs on the HMCAD15XX ADCs accept CMOS, LVDS, LVPECL and sine wave inputs. Connect a clock source to the SMA connector named CLK. The EasyBoard clock network is an AC coupled balun configuration with a 20MHz lower frequency limit. The network will accept a single ended sine wave or square wave input.
For best possible performance it is very important that the clock source have low jitter. Poor jitter performance will directly result in reduced SNR. The SNR contribution from jitter is given by equation (1) assuming a full scale input signal at frequency, FIN, and TRMS-jitter, measured in second Root-Mean-Square.
One can see that a 1ps clock jitter with a 25 MHz full scale input results in an additional SNR component of 76 dBc. Because of this the clock signal should be treated with the same care as the analog inputs to the ADC.
This connector is directly routed to a general input/output pin on the FPGA. It can be used to apply an external trigger.
Figure 2. Hardware Configuration (click on enlarge)
Figure 3. Default Analog Input Network
JP4 and JP5 in lower right corner (see Figure 9) must be set to enable power for all power domains to the converter. One jumper must be present on each row, either to the right or the left. Setting the jumper to the right includes that power domain in the built-in current measurement feature. Setting the jumper to the left bypasses the current measurement for that domain.
All the power domains are on the 1.8 V power supply. The domains are separated on the board so that it is possible to measure the current consumption individually for each power domain on the chip. The domains are as follows:
JP1 in Figure 9 selects the source for common mode drive. The source is the common mode level for the differential input signals. If the jumper is placed in the top position, the common mode is driven by the common mode output of the ADC. The drive strength of this output is programmable from the configuration software. See the HMCAD1511/ HMCAD1520 data sheet for details regarding the drive strength. If the jumper is placed in the lower position, the common mode is set by two on-board 51 Ω resistors between the 1.8 V supply and ground. It is possible to override this common mode externally by connecting a voltage source to the terminal port JP2 in the lower left corner.
Terminal JP5 provides a 3.3 V supply outlet. This supply originates from the power converters on the mother board such as the SP601. It can drive a load up to 5 A. JP5 can be used as a power supply for an external crystal oscillator, which can be used as a clock source.
The FMC connector J1 is located on the backside of the board. Connect J1 with the FMC connector on the Xilinx mother board.
U4 is a power monitoring chip. U4 can measure the current consumption and voltage level from the ADC. See the Power Domains section for details about measuring different power domains on the ADC. If all jumpers on JP4 and JP5 are placed to the right, the total power consumption of the chip is measured.
The EasySuite software controls and collects data from the monitoring chip.
If the power measurement gives unexpected results, try bypassing the OVDD domain from the power measurement circuit.
The supply voltage level for the ADC can be adjusted through the EasySuite software. U12 is a digital potentiometer which can adjust the supply level between 1.7 V and 2.0 V. Refer to the EasySuite software user guide for an explanation of how to set the supply voltage.
Figure 4. Evaluation Board Schematic, ADC, and Decoupling (click to enlarge)
Figure 5. Evaluation Board Schematic, Analog Input Buffer (click to enlarge)
Figure 6. Evaluation Board Schematic, Clock Input (click to enlarge)
Figure 7. Evaluation Board Schematic, FMC Connector (click to enlarge)
Figure 8. Evaluation Board Schematic, Power Converter and Current Measurement (click to enlarge)
Figure 9. Component Placement, Top
Figure 10. Component Placement, Bottom
Figure 11. Top Layer
Figure 12. Inner Layer, Top
Figure 13. Inner Layer, Bottom
Figure 14. Bottom Layer
Refence Designator | Description |
ADC1 | High speed multimode 12-bit/14-bit, 40 MSPS to 640 MSPS A/D converter |
D1 | Rectifier Schottky 30 V, 1.5 A, 3-2A1A |
J1 | Connected single end array male 160 position |
JP1 | Terminal strip, single row 3-pin 0.100”, TRW |
JP3 | Terminal strip, single row 4-pin through 0.100”, TLW |
JP4 | Terminal strip, dual row 2×4 through 0.100”, TLW |
L13 | Inductor shield power 3.3 μH 7045 |
R45 | Resistor 0.20 Ω 1/4 W, 1%, 0805 SMD |
R48 | Resistor 100 kΩ 1/10 W, 1% 0603 SMD |
R50 | Resistor 10.0 kΩ 1/10 W, 1% 0603 SMD |
U12 | Integrated circuit (IC) pot digital SPI 256 position SOT23-8 |
U4 | IC current monitor 1% SOT23-8 |
U5 | IC regulator buck 1.5 A SOT23-5 |
C34 to C35 | Capacitor ceramic 47 μF, 6.3 V, X5R 20% 0805 |
CLK, TRIG | Connected receptor straight printed circuit board (PCB) 0.155” G |
JP2, JP5 | Terminal strip, SGL Row 2, pin through 0.100”, TLW |
R3, R49 | Resistor 20 kΩ 1/10 W, 1% 0603 SMD |
R42 to R42 | Resistor 0 Ω 1/16 W, 5% 0402 SMD |
R43 to R44 | Resistor 51 Ω 1/10 W, 1% 0603 SMD |
U1, U3 | Schottky diode, radio frequency (RF), bridge quad |
INP1 to INP4 | SCD, MA-F, edge launch, 0.031” board, Johnson |
R11 to R12, R23 to R24 | Resistor 51 Ω 1/10 W, 1% 0402 SMD |
R25 to R26, R36 to R37 | Resistor 10.0 k Ω 1/16 W, 1% 0402 SMD |
R46 to R47, R51, R53, R57 | Resistor 0 Ω 1/10 W, 5% 0603 SMD |
TR1 to TR4, TRCLKB | RF transformer, 50 Ω, 4.5 MHz to 3000 MHz, TC!-1-13M+ |
C5, C8, C10, C12, C31 to C33, C44 | Capacitor ceramic 1 μF, 25 V, 15% X5R 0603 |
R7 to R10, R19 to R22 | Resistor 24 Ω 1/10 W, 1% 0402 SMD |
RIN1 to RIN4, RIP1 to RIP4 | Resistor 10 Ω 1/10 W, 1% 0402 SMD |
C13 to C20, C28 to C29 | Capacitor ceramic 0.1 μF, 50 V, 10% X7R 0402 |
C3 to C4, C6 to C7, C9, C11, C21 to C24 | Capacitor ceramic 0.01 μF, 50 V, 10% X7R 0402 |
C1 to C2, C25 to C27, C30, CF1 to CF4, Q1 to Q2, R1 to R2, R13 to R14, R27 to R35, R38 to R40, R52, R54 to R56, R58, U2 | Do not populate components |
