DSG300 is the all-in-one DTV signal generator supporting MPEG2 TS and RF Signal generation in one unit. It can cover all DTV standard in one unit including DVB-T, DVB-C, DVB-S, ATSC and OpenCable.
DSG300 offers easy connection to various digital television signal sources and receivers, suitable for high-definition and standard definition digital television.
If you want DTV signal generator with multi standard in one unit, DSG300 is the most cost-effective solution which supports Multi-DTV standard and reasonable RF performance for below applications.
DTV Signal Generator - DSG500L RF Specifications
DSG500 is the all-in-one DTV signal generator supporting MPEG2 TS and RF Signal generation in one unit. It can cover all DTV standards in one unit including DVB-T, DVB-C, ATSC, OpenCable, DVB-S/S2 and DTMB(DMB-TH). DSG500 offers easy connection to various digital television signal sources and receivers suitable for high-definition (HD) and standard definition (SD) digital television.
Most importantly, DSG500 supports multi signal output (Max. 2 RF) in one unit that allows using signal simultaneously.
It will save your cost and time for buying several other DTV signal generators.
