ISL29002 pdf datasheet (Light-
消耗积分:3 | 格式:rar | 大小:211 | 2009-01-15
分享资料个
The ISL29002 is an integrated light sensor with a built-in
integrating type ADC and a standard I2C interface. The
device transforms illuminance, ambient light level in lux, into
a digital output signal accessible through I2C. The sensor
precisely converts illuminance from 1lux to 100,000lux. The
ADC features up to 15-bit effective resolution. The sensor
includes another photodiode covered with metal to reduce
the effects of dark output reading that may be significant in
low lux levels.
The ISL29002 can control display panel backlighting depending
on ambient light conditions, adding artificial intelligence by
approximating the response of a human eye. The ISL29002
can also manage portable peripheral illumination based upon
lighting conditions extending battery life.
In normal operation, the ISL29002 consumes less than 300μA
of supply current. A software power down mode is controlled
via the I2C interface and disables all but the I2C interface. The
supply current is then reduced to less than 88μA.
Designed to operate on supplies from 2.5V to 3.3V, the
ISL29002 is specified for operation over the -40°C to +85°C
ambient temperature range. It is packaged in a clear, Pb-free
8 Ld ODFN package.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
