工程师小经验:快速查找原理图元器件资料资料下载
消耗积分:10 | 格式:pdf | 大小:404.42KB | 2021-04-03
20762
分享资料个
我们在设计原理图或者查看原理图时,经常需要到网站上搜索某个元器件的相关资料,看能否找到规格书来查看。每次都要打开相关网站,输入关键词去搜索,这样的重复操作效率不是很高。有没有办法在原理图上,选中某个元器件,下一步就已经在网站上搜索了这个元器件的关键词,并找出了相关网页来。答案是有的,就是编写一个脚本,选中某个元器件,运行脚本就能实现这个功能。下面介绍一下这个方法。 首先,打开原理图的脚本编辑器,编写以下代码。 参考代码: Sub Main Begin Dialog UserDialog 260,140,"Select a Web ",.CallbackFunc ' %GRID:10,7,1,1 Text 50,84,170,14,"",.Text1 OKButton 40,112,90,21,.OK CancelButton 140,112,90,21  OptionGroup .Manufacturer OptionButton 60,14,140,14,"baidu",.OptionButton1 OptionButton 60,35,90,14,"szlcsc",.OptionButton2 OptionButton 60,56,90,14,"taobao",.OptionButton3 End Dialog Dim dlg As UserDialog Dim attrs As Attributes If Dialog(dlg) = -1 Then 'OK was pressed Set objs = ActiveDocument.GetObjects(plogObjectTypeComponent, "", True) For Each part In objs Set attrs = part.Attributes compName = attrs("Value") Next part 'compName = objs.Item(1).AttrVal(part, "Description") Set ie = CreateObject("InternetExplorer.Application") 'compName = objs.Item(1).AttrVal(part, "Description") Set ie = CreateObject("InternetExplorer.Application") ie.Visible = True Select Case dlg.Manufacturer Case 0 'ie.Navigate("http://www-s.ti.com/sc/docs/psheets/pids2.htm") ie.Navigate("http://www.baidu.com/s?wd="& compName) SendKeys compName & "~" Case 1 ie.Navigate("https://so.szlcsc.com/global.html?&hot-key=CC2530F256RHAR") Case 2 ie.Navigate("https://s.taobao.com/search?keywords=" & compName) End Select End If End Sub Rem See DialogFunc help topic for more information. Private Function CallbackFunc(DlgItem$, Action%, SuppValue%) As Boolean Select Case Action% Case 1 ' Dialog box initialization Document_SelectionChange Case 2 ' Value changing or button pressed Case 3 ' TextBox or ComboBox text changed Case 4 ' Focus changed Case 5 ' Idle Rem CallbackFunc = True ' Continue getting idle actions End Select End Function Public Sub Document_SelectionChange() Set objs = ActiveDocument.GetObjects(plogObjectTypeComponent, "", True) DlgEnable "OK", False If objs.Count = 1 Then compName = objs.Item(1).Name DlgText "Text1", "Selected Part: " & compName DlgEnable "OK", True ElseIf objs.Count > 1 Then DlgText "Text1", "Multiple Selection" Else DlgText "Text1", "Select a part" End If End Sub   然后,选中需要查找的元器件,运行脚本,就会弹出一个网站的页面让我们选择,这里设置了百度,立创和淘宝。 最后,任选其中一个网站,点击确认,就会自动打开相对应的网站,搜索元器件的关键词,找到相关的内容供我们查看,非常方便快捷。
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
