7906CT pdf,7906CT datasheet
消耗积分:5 | 格式:rar | 大小:333 | 2009-01-19
分享资料个
The 7906CT series of fixed output negative voltage regulators are
intended as complements to the popular MC7800 series devices.
These negative regulators are available in the same seven–voltage
options as the MC7800 devices. In addition, one extra voltage option
commonly employed in MECL systems is also available in the
negative 7906CT series.
Available in fixed output voltage options from –5.0 V to –24 V,
these regulators employ current limiting, thermal shutdown, and
safe–area compensation – making them remarkably rugged under
most operating conditions. With adequate heatsinking they can deliver
output currents in excess of 1.0 A.
• No External Components Required
• Internal Thermal Overload Protection
• Internal Short Circuit Current Limiting
• Output Transistor Safe–Area Compensation
• Available in 2% Voltage Tolerance (See Ordering Information)
评论(0)
发评论
下载排行榜
