基于TCR6DA_Typical Application直流到直流多输出电源的参考设计
消耗积分:2 | 格式:pdf | 大小:301.84KB | 2021-07-14
分享资料个
说明
  • Typical Application for TCR6DA1833U, 200mA, 3.3V and 1.8V Output Voltages Dual Outputs CMOS Low-Dropout Regulator. The TCR6DA series are CMOS general-purpose dual-outputs voltage regulators with independent on/off control inputs, featuring low dropout voltage and low quiescent bias current. The TCR6DA series can be enabled and disabled via the CONTROL pin for each LDOs. These voltage regulators are available in fixed output voltages between 1.5V and 3.3V in 0.1V steps and capable of driving up to 200 mA. These devices are ideal for portable applications that require high-density board assembly such as cellular phones
主要特色
  • Conversion Type
    DC to DC
  • Topology
    LDO
评论(0)
发评论
下载排行榜
