SOT23-3EV-VREG, MCP1701A SOT23-3 Voltage Regulator Evaluation Board is designed to evaluate and test voltage regulators. The SOT23-3 Voltage Regulator Evaluation Board does not come with a voltage regulator soldered onto the board. This allows the user to attach the voltage regulator of their choosing to the board and perform quiescent current, ground current, Power Supply Ripple Rejection (PSRR), and other desired tests. It is based upon a modular concept which will allow the user to plug in additional boards to increase the test capability of the voltage regulator
