The step-up DC-DC converter provides the regulated supply voltage for panel source driver ICs. The high 1.2MHz switching frequency allows the use of ultrasmall inductors and ceramic capacitors. The current-mode control architecture provides fast-transient response to pulsed loads typical of source driver loads. The step-up regulator features an adjustable soft-start and an adjustable cycle-by-cycle current limit.
The high-current operational amplifier is designed to drive the LCD backplane (VCOM). The amplifier features high output current (±200mA), fast slew rate (50V/μs), wide bandwidth (12MHz), and rail-to-rail inputs and outputs.
The low-voltage LDO linear regulator has an integrated 0.8
pass element and can provide at least 350mA. The output voltage is accurate within ±1%. The high-voltage, level-shifting scan driver is designed to drive the TFT panel gate drivers. Its three outputs can swing up to 40V (max) to swiftly drive capacitive loads. To save power, the two complementary outputs are designed to allow charge sharing during state changes.
The MAX17103 is available in a 32-pin, 5mm x 5mm, thin QFN package with a maximum thickness of 0.8mm for thin LCD panels.
