网络化资源配置中的制造资源模型研究
消耗积分:3 | 格式:rar | 大小:223 | 2009-02-27
hxjq
分享资料个
分析了制造资源在区域网络化配置中的特点,研究了区域网络化资源优化配置对其资源模型的要求。采用面向对象的统一建模语言方法建立了面向区域网络化资源优化配置的装备资源两级模型,为区域网络化资源优化配置提供了支撑,并为其他资源模型的建立提供了重要参考。
关 键 词 区域网络; 资源配置; 制造资源; 特性; 两级模型
Abstract The network manufacturing system for optimally allocating and restructuring manufacturing resources is an important part and evolution of Chengdu-Deyang-Mianyang Region’s manufacturing industry. Manufacturing resource modeling of this system is necessary and valuable. In the paper, manufacturing resource characteristics of this system are analyzed, the modeling requirements of manufacturing resource for this system are researched, modeling process using object-oriented is then analyzed. Based on above work, the two-level manufacturing resource model based on UML is set up. The two-level model has an important reference for other resource model and it can support regional network manufacturing system well.
Key words regional network; resource allocating and restructuring; manufacturing resource; characteristics; two-level mod
评论(0)
发评论
下载排行榜
