提出了一种采用三分支干涉型调制器来实现单边带副载波标签的光分组产生方案,通过理论分析和仿真实验表明该方案实现了副载波标签的单边带调制,克服了Mach-Zehnder调制器强度调制导致的副载波信号的非线性失真,但存在着净荷信号对副载波标签信号的强度调制。
关 键 词 光标签交换; 副载波复用; 调制器; 消光比
Abstract A novel optical packet generation scheme is proposed based on three branch modulator.Theory analysis and simulation demonstrate that the scheme realizes subcarrier multiplexing label of single sideband and overcomes the nonlinear modulation of Mach-Zehnder modulator on subcarrier signal. The problem of intensity modulation on subcarrier multiplexing label from payload is analyzed.
Key words optical label switching; subcarrier multiplexing; modulator; extinction ratio
