Intro
As an iOS user, when you are building a smart home with the homebridge, you have to fill in the Homebridge config with some information like a local IP or token of your smart devices. In most cases, the miIO device library can help you to obtain this information.
But sometimes miIO can't extract the token, or an extracted token is invalid, or even miIO does not see the device at all. In this case, you can get the needed information from the Mi Home app by following this steps. But this instruction is complex. So here is mihome-backup-viewer! This tool executes these steps for you. All you need is:
- create an unencrypted iOS backup;
run
mihome-backup-viewerand follow the instructions; - copy and paste the desired information.
Install
Install it globally:
npm i -g mihome-backup-viewer
How to use
Just run this command and follow the instructions:
Troubleshooting
- Make sure you creating an unencrypted backup.
- Make sure your terminal app has permissions to read the backups folder: → System Preferences → Security & Privacy → "Privacy" tab → select "Full Disk Access", and then click the [+] plus button to add the terminal app.
