age文件加密工具
消耗积分:2 | 格式:zip | 大小:0.20 MB | 2022-05-06
张波
分享资料个
授权协议 BSD-3-Clause
开发语言 Google Go
操作系统 跨平台
软件类型 开源软件
所属分类 管理和监控安全相关
软件简介
age 是一个简单、现代和安全的文件加密工具(和 Go 库),具有小的 explicit keys、无配置选项、以及 UNIX 风格的可组合性。
$ age-keygen -o key.txt
Public key: age1ql3z7hjy54pw3hyww5ayyfg7zqgvc7w3j2elw8zmrj2kg5sfn9aqmcac8p
$ tar cvz ~/data | age -r age1ql3z7hjy54pw3hyww5ayyfg7zqgvc7w3j2elw8zmrj2kg5sfn9aqmcac8p > data.tar.gz.age
$ age --decrypt -i key.txt data.tar.gz.age > data.tar.gz
格式规范位于 age-encryption.org/v1
示例:
有关完整文档,可阅读  the age(1) man page
Usage:
    age [--encrypt] (-r RECIPIENT | -R PATH)... [--armor] [-o OUTPUT] [INPUT]
    age [--encrypt] --passphrase [--armor] [-o OUTPUT] [INPUT]
    age --decrypt [-i PATH]... [-o OUTPUT] [INPUT]
Options:
    -e, --encrypt               Encrypt the input to the output. Default if omitted.
    -d, --decrypt               Decrypt the input to the output.
    -o, --output OUTPUT         Write the result to the file at path OUTPUT.
    -a, --armor                 Encrypt to a PEM encoded format.
    -p, --passphrase            Encrypt with a passphrase.
    -r, --recipient RECIPIENT   Encrypt to the specified RECIPIENT. Can be repeated.
    -R, --recipients-file PATH  Encrypt to recipients listed at PATH. Can be repeated.
    -i, --identity PATH         Use the identity file at PATH. Can be repeated.
INPUT defaults to standard input, and OUTPUT defaults to standard output.
If OUTPUT exists, it will be overwritten.
RECIPIENT can be an age public key generated by age-keygen ("age1...")
or an SSH public key ("ssh-ed25519 AAAA...", "ssh-rsa AAAA...").
Recipient files contain one or more recipients, one per line. Empty lines
and lines starting with "#" are ignored as comments. "-" may be used to
read recipients from standard input.
Identity files contain one or more secret keys ("AGE-SECRET-KEY-1..."),
one per line, or an SSH key. Empty lines and lines starting with "#" are
ignored as comments. Passphrase encrypted age files can be used as
identity files. Multiple key files can be provided, and any unused ones
will be ignored. "-" may be used to read identities from standard input.
When --encrypt is specified explicitly, -i can also be used to encrypt to an
identity file symmetrically, instead or in addition to normal recipients.
评论(0)
发评论
下载排行榜
