neovim-elixir Neovim主机插件Elixir
消耗积分:2 | 格式:zip | 大小:0.01 MB | 2022-05-24
自我清欢
分享资料个
授权协议 未知
开发语言
操作系统 跨平台
软件类型 开源软件
软件简介
Neovim 主机插件 Elixir 。
示例代码;
defmodule AutoComplete do
  use NVim.Plugin
  deffunc elixir_complete("1",_,cursor,line,state), eval: "col('.')", eval: "getline('.')" do
    cursor = cursor - 1 # because we are in insert mode
    [tomatch] = Regex.run(~r"[\w\.:]*$",String.slice(line,0..cursor-1))
    cursor - String.length(tomatch)  end
  deffunc elixir_complete(_,base,_,_,state), eval: "col('.')", eval: "getline('.')" do
    case (base |> to_char_list |> Enum.reverse |> IEx.Autocomplete.expand) do
      {:no,_,_}-> [base] # no expand
      {:yes,comp,[]}->["#{base}#{comp}"] #simple expand, no choices
      {:yes,_,alts}-> # multiple choices
        Enum.map(alts,fn comp->
          {base,comp} = {String.replace(base,~r"[^.]*$",""), to_string(comp)}          case Regex.run(~r"^(.*)/([0-9]+)$",comp) do # first see if these choices are module or function
            [_,function,arity]-> # it is a function completion
              replace = base<>function
              module = if String.last(base) == ".", do: Module.concat([String.slice(base,0..-2)]), else: Kernel
              if (docs=Code.get_docs(module,:docs)) && (doc=List.keyfind(docs,{:"#{function}",elem(Integer.parse(arity),0)},0)) && (docmd=elem(doc,4)) do
                 %{"word"=>replace,"kind"=> if(elem(doc,2)==:def, do: "f", else: "m"), "abbr"=>comp,"info"=>docmd}              else
                %{"word"=>replace,"abbr"=>comp}              end
            nil-> # it is a module completion
              module = base<>comp              case Code.get_docs(Module.concat([module]),:moduledoc) do
                {_,moduledoc} -> %{"word"=>module,"info"=>moduledoc}                _ -> %{"word"=>module}              end
          end
        end)    end
  end
  defautocmd file_type(state), pattern: "elixir", async: true do
    {:ok,nil} = NVim.vim_command("filetype plugin on")
    {:ok,nil} = NVim.vim_command("set omnifunc=ElixirComplete")
    state  endend
评论(0)
发评论
下载排行榜
